SBG8300 makes a whirring noise
  • January 9, 2023
  • 137 views
My ARRIS SURFboard SBG8300 occasionally makes a whirring noise.  I've only had it for 7 months.  Should I be alarmed?  Thanks for any help.
Hello JDuty,
I understand that your modem makes whirring noise occasionally, sorry for the inconvenience . Please don't worry .
For warranty support, please visit https://arris.com/consumersupport
  • January 12, 2023
Thank you.  Tech support says no need to worry, and that I should put the modem 5’ above the floor.  I’m supposed to monitor for a week and re-call tech support if whirring noise continues.
