Ethernet ports not working sgb6580
  • April 17, 2025
  • 33 views
They were working fine, and then they just stop transferring data
I recommend restarting the gateway first. If there are still no connections from the Ethernet port, try using a different Ethernet cable. Make sure to check for LED light indications at the Ethernet ports which indicates a data transfer.
