Sbg6400 router not connecting
  • December 19, 2022
  • 46 views
I have little to no tech knowledge.  My router is no longer allowing certain items to connect.  Can not authenticate is the what it shows.  I have tried factory reset and still get the same result.  Any tips?
Hello Spearfishin 18,
Could you please let us know the devices that are not getting connected . Basically we have two networks (2.4 ghz and  5ghz) , certain devices gets connected to both or either one of them. .
Make sure you connect to your  wifi network of the device. Also ensure that you type in the wifi password correctly as it is case sensitive .
