sbg6580 - how to connect security system with 5g network.
  • February 24, 2024
  • 32 views
Howcan I open 5G on this Router, to use my security system??
I am getting the run around
sbg6580 device is compatible for only one network at a time and when you enable 5G network it will cover only 10 feet so connecting security system with 5G network is not advisable.
