i cannot log into the modem online. I have hard reset multiple times and the default username and password are not working
SBG6700-AC cannot log into modem and hard reset default password and username not working
As you mentioned, you unable to login GUI portal with default username as admin and password as password. Also I understand that you already tried with reset multiple times.
I suggest you to follow the steps and try again to login the GUI portal with default credentials.
Disconnect all the cables from the modem including power cord.
Wait for a minute and reconnect only the power cord, hold the reset button for 30 seconds by using paperclip.
After 30 seconds, release the hold and reconnect all the cables back to the modem.
Once led light solid, log on to 192.168.0.1 and use the default credentials as admin (USERNAME) and password (PASSWORD).
