changing carrier
  • November 25, 2024
  • 44 views
I have a model NVG558HX that I bought from Verizon. I typed the model# in the ARRIS site and it doesn't come up. My question is, I got rid of Verizon and got a chip from AT&T and put it in. It turns on broadcast wifi, but won't connect to AT&T towers.
Can I change a setting to get it to work?
Or should I call AT&T to see what they can do.
Arris supports only the retail products that are available on surfboard.com but not the ISP lease products. Please contact your ISP for further assistance.
  • November 25, 2024
pretty sure that was a direct to verizon device. I haven’t found anywhere that it works with any provider other than verizon.
Unless you want to use the WAN port versus cellular
  • November 26, 2024
I was hopeful that it would work on other carriers.
Not sure why it won't, but it doesn't connect. Thank you
