Can I use W21's as Access Points?
Where the Wild Pings Are
Cable Modem Commandos
Forum|alt.badge.img+9
Can I setup my w31 2-pack as access points to my service provider modem/router combo? I have a wifi 6 modem from xfinity which if possible I would like to use the w31 as access points only.
Best answer by dan_w
Yes, this is possible. In the Surfboard Central app, look under Network → Network Settings → General Settings and enable Bridge Mode.
  • 2287 replies
  • May 27, 2022
The w31 should have an access point mode. It did the last time I used it.
  • Button Mashers
  • 9 replies
  • May 31, 2022
