Enable loopback on w31 mesh router
  • March 17, 2023
  • 54 views
I want to be able do loopback testing.  I have a website I’m developing locally but I either need to test it on my own machine or from an external one but I can’t visit the external IP from my local machine.
Hello xksteven,
As you are experiencing trouble visiting from external IP from local machine
I would recommend you to do a Port Forwarding for 80 TCP or 80 TCP/UDP to the web browser.
Once done you can try to access the website in your mobile phone using your mobile data service.
Let us know if this helps.
  • March 24, 2023
This is cumbersome to be forced to switch devices to verify that external IP is working.
I can't say I would recommend this router to other developers knowing this router lacked this feature or was not developed for the router.
