S34 2.5 gig port won't work with TP-Link BE3600 (1 gig port does)
Yesterday, during a pretty heavy thunderstorm my trust TP-link Archer AX55 suddenly stopped working-it had the one green powerlight, but no other lights after several reboots and hard resets.
So I fire up amazon and order a BE3600, figuring I’d get to use the 2.5 gig ports on both the S34 and the BE3600.
Strangely, when I connect the cable from the 2.5 port, there is nothing, no lights no connection.  When I connect via the 1 gig port, everything comes to life. Now I had been using the 2.5 port with my old, 1 gig port modem and it seemed to be ok with working with a slower port.  Now, with the 2.5 capable router, , the port just goes dead.  I have done a ton of power cycles-no difference...
Now, i’m not at a crazy high tier with Xfinity, so I likely wouldn’t see much of a difference, if any. but I’m curious- is there a setting I’m missing
Make sure that only the 2.5G port is connected on the S34 modem, leaving the 1G port empty. Restart the modem and check the light status on the 2.5G port. If there are no lights, the port might be malfunctioning. At this stage, perform a factory reset. If there is still no connection on the 2.5G port after the reset, further troubleshooting may be needed.
  1. Click on the Apple menu.
  • July 4, 2025
Thank you for the guidance and further ideas- I tried the power cycle with the ethernet already hooked up, and then the factory reset- sadly no change. I’ve tried 3 different cables, including a brand new Cat 7, and still no connection or lights from the 2.5 port.  I’m afraid I don’t have PCs that have ethernet ports anymore, and am not sure it’s worth buying a hub just to test this, I think the port is malfunctioning. I bought the unit in Dec 2024, so it should still be under warranty, correct?
Thanks!
That's correct! If your S34 modem is not a refurbished unit and is purchased from an authorized reseller, you will receive a two-year manufacturer's warranty starting from the date of purchase. If you are experiencing issues, such as no lights on the Ethernet port when connected to a router, try factory resetting the modem. If the problem persists, please reach out to our support team by visiting www.arris.com/consumersupport.
