Network name is not broadcasting on SB6190
  • April 8, 2024
  • 162 views
My modem is not showing up and my network my Wi-Fi is working properly from Comcast internet but my device is not showing up I need help
SB6190 is just a cable modem so it doesn't have inbuilt Wi-Fi on it and to access Wi-Fi you need to connect separate router to the modem LAN port.
If you have any device for direct connection connect the device directly to the modem ethernet port and check for the internet.
