SB6190 modem - Upload Speed Slow
  • August 16, 2024
  • 69 views
My internet provider is comcast.
I rent the xfinity modem&wifi for a year. Speed is totally great ( Down 300 up 150)
And I bought SB6190 to replace it. But up speed is terrible I only got 5.
I only have 4 upload stream bound.
Does anyone using SB6190 and get more than 5 upload speed?
If you are with 150Mbps upload speed plan then that is not compatible speed for SB6190 model so you need to check for the compatible speed with your service provider and change the speed plan accordingly to get proper speed from SB6190.
