Connecting an HP Deskjet 2600 wireless printer
  • October 27, 2023
  • 338 views
I’m trying to set up an HP Deskjet 2600 to my Wi-Fi. I was online before, but I got a new internet and SB8200 modem
Best answer by robela01
I finally called my Wi-Fi provider. I had to update my router. All good now.
LoveMyLab
Guardians of the Gateways
Forum|alt.badge.img+19
  • Guardians of the Gateways
  • October 27, 2023
If you kept the same router, the new SB8200 should not have any effect on you HP Deskjet. What specifically isn’t working? Note: If you are setting up the HP for the first time, I encourage you to use a static IP address.
  • October 27, 2023
