How do I connect my SBG10 to the internet using ethernet?
  • December 13, 2024
  • 116 views
Hi! I have just moved to a new apartment, and do not have any coax outlets--I only have ethernet. I had bought an SBG10 (modem/router combo) before I moved in, but now I’m not sure if I can connect it to the internet using ethernet. The outlet in the apartment gives my laptop access to the internet (with an ethernet cable), but not my SBG10.
Any help would be appreciated!
Thanks!
Best answer by Netopia
You can’t use the SBG10 since it’s intended for cable internet.  You will need a Wi-Fi router that has Ethernet connection for the WAN or Internet port.
Forum|alt.badge.img+30
  • Rockstar!
  • 274 replies
  • December 13, 2024
  • December 13, 2024
Makes sense. Thanks!
