SBG7400AC2 wifi speed
  • November 14, 2022
  • 119 views
How can I increase the Wi-Fi speed to my devices from the SBG7400AC2 unit? Connection speed via ethernet is 277 mbps, when testing using WI-FI 62 mbps. Thank you
  1. what device are you testing with?
  2. are you testing over 2.4ghz or 5ghz? 2.4ghz is a slow network and sensitive to interference. that’d actually be a decent speed over 2.4ghz. Not so much over 5ghz
  3. how far from the router are you?
  • November 15, 2022
  • November 15, 2022
I guess those are some items I need to keep track of. I am pretty sure I was using the 2.4ghz, just realized there is a 5ghz. and was using my cell phone and was right in front of the mode/router.
I was contemplating putting the SBG7400AC2 in Bridged Mode and getting a separate WIFI 6 router. Do you think that will help with speed and range?
Thank you
  1. what device are you testing with? Cell Phone
  2. are you testing over 2.4ghz or 5ghz? 2.4ghz is a slow network and sensitive to interference. that’d actually be a decent speed over 2.4ghz. Not so much over 5ghz 2.4ghz
  3. how far from the router are you?  Right in front.
