Router NVG578LX: how to turn on 2.4GHz with wireless IEEE802.11b/g/n standards
  • September 5, 2024
  • 277 views
Hi all,
I am using an ARRIS router model NVG578LX provided by an internet provider.
I need some help on how to turn on the 2.4GHz channel with wireless IEEE802.11b/g/n standards.
It is because my desktop doesn’t have a built in wifi adapter hence I have to use an Edimax usb which only works with the IEEE802.11b/g/n standards.
I have successfully turned on the 2.4GHz separated from the combine channel (the primary). I also tried turn on and off the 5Ghz. Unfortunately, the Edimax usb couldn’t find (see) the 2.4GHz network.
Noting that:
  1. All the phones and laptops can find/see and access to the 2.4GHz.
  2. I also tried to turn on the Guess wifi with 2.4Ghz (but the Edimax coudn’t find/see the network).
  3. the Edimax usb still can see other network providers from the neighbours surrounding.
  4. the Edimax usb worked well with the previous internet provider using a different router (not from ARRIS) but only when I turned on the IEEE802.11b/g/n standards using the settings. it seems this is the key issue. Unfortunately, I couldn’t find the option in the current model.
Thanks for your help.
Andy
Arris supports only the retail products that are available on surfboard.com but not the ISP lease products.
