extender for ARRIS (G34) - Cable Modem Router Combo - Fast DOCSIS 3.1 Gigabit WiFi 6 (AX3000)
  • September 19, 2024
  • 438 views
what extender do you recommend for an additional 1200sf for the this product:
Thank you
G34 is compatible with all brand extenders so you can use according to the requirement and we would recommend you to go with Mesh Wi-Fi system which will also work as extenders and you can check for the product details and specifications on the official shopping site of Arris that is shop.surfboard.com
