Unsafe WiFi Network Alert - G34
  • November 21, 2023
  • 268 views
After my G34 dropped the SSID for the 5G I had to reset it. It now will not allow me to change the password, so I had to change it on my computers.
When I connect to the network now my Bitdefender alerts me that it is an unsafe network.
I’m using the recommended WPA2/WPA3 security on the router.
In this case we would suggest you to change the WIFI channel for 5G network by following the steps mentioned on the below article and also you can change the security mode to   WPA/WPA2-PSK(TKIP/AES)
