DOCSIS 3.0 Cable Modem &WI-FI Router
  • February 28, 2025
  • 44 views
I am thinking having Spectrum as my Internet provider and they provide a modem but I was wondering if my existing equipment is compatible
Surfboard
DOCSIS 3.0 ( SBG6950AC2 )
Any thoughts would be grateful
According to Spectrum/Charter, while they have previously approved this gateway, they will no longer facilitate new activations for this model. We would recommend upgrading your gateway to a DOCSIS 3.1 model.
Additionally, you may want to check with Spectrum to see if they still provision DOCSIS 3.0 in your area. If so, you can continue using this model for now, but we would still suggest considering an upgrade to a DOCSIS 3.1 gateway.
  • 2303 replies
  • February 28, 2025
Thats an older/slower modem/router combo device you have. They’ll probabably only provide you a modem free. Its more up to you if you’d like to stick with what you have or upgrade to a better router
  • March 9, 2025
Thanks for all your advice.
