What cable modem supports port forwarding?
  • August 20, 2023
  • 168 views
I would like to get a new cable modem (Cox compatible) that will support DHCP and port forwarding configurations.  I bought the SB6190 not realizing it does not.  Wi-Fi is optional.  Thanks
SB6190 is the cable modem and it doesn't support Wi-Fi  and port forwarding configurations.
If you are preferring for port forwarding and DHCP configurations, we recommend you to buy Wi-Fi cable modems such as SBG10, G34, G36 etc.
For more information, visit our official website https://shop.surfboard.com.
LoveMyLab
Guardians of the Gateways
Forum|alt.badge.img+19
  • Guardians of the Gateways
  • August 31, 2023
I would simply add a router that meets your requirements and has an interface you like.
